BACnetAddress
BACnetAddress
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•accessDoor.valueSource
•accessDoor.valueSourceArray
•analogOutput.valueSource
•analogOutput.valueSourceArray
•analogValue.valueSource
•analogValue.valueSourceArray
•binaryLightingOutput.valueSource
•binaryLightingOutput.valueSourceArray
•binaryOutput.valueSource
•binaryOutput.valueSourceArray
•binaryValue.valueSource
•binaryValue.valueSourceArray
•bitstringValue.valueSource
•bitstringValue.valueSourceArray
•channel.valueSource
•characterstringValue.valueSource
•characterstringValue.valueSourceArray
•command.valueSource
•dateValue.valueSource
•dateValue.valueSourceArray
•datepatternValue.valueSource
•datepatternValue.valueSourceArray
•datetimeValue.valueSource
•datetimeValue.valueSourceArray
•datetimepatternValue.valueSource
•datetimepatternValue.valueSourceArray
•integerValue.valueSource
•integerValue.valueSourceArray
•largeAnalogValue.valueSource
•largeAnalogValue.valueSourceArray
•lifeSafetyPoint.valueSource
•lifeSafetyZone.valueSource
•lightingOutput.valueSource
•lightingOutput.valueSourceArray
•loadControl.valueSource
•multiStateOutput.valueSource
•multiStateOutput.valueSourceArray
•multiStateValue.valueSource
•multiStateValue.valueSourceArray
•octetstringValue.valueSource
•octetstringValue.valueSourceArray
•positiveIntegerValue.valueSource
•positiveIntegerValue.valueSourceArray
•timeValue.valueSource
•timeValue.valueSourceArray
•timepatternValue.valueSource
•timepatternValue.valueSourceArray
Esquema XML
  <xs:complexType name="BACnetAddress">
    <xs:sequence>
      <xs:element name="NetworkNumber" type="Unsigned16" />
      <xs:element name="MacAddress" type="OctetString" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetAddress" />
</xs:schema>
Exemplos
Exemplo 1:
  <BACnetAddress>
    <NetworkNumber>7634</NetworkNumber>
    <MacAddress>00010203040506070809</MacAddress>
  </BACnetAddress>
</Value>
