Objeto octetstringValue
Defines a standardized object whose properties represent the externally visible characteristics of a named data value in a BACnet device. A BACnet device can use an OctetString Value object to make any kind of OCTET STRING data value accessible to other BACnet devices. The mechanisms by which the value is derived are not visible to the BACnet client.
Objetos do tipo octetstringValue possuem as seguintes propriedades:
•commandTimeArray
•currentCommandPriority
•description
•eventState
•lastCommandTime
•objectIdentifier
•objectName
•objectType
•outOfService
•presentValue
•priorityArray
•profileLocation
•profileName
•propertyList
•reliability
•reliabilityEvaluationInhibit
•relinquishDefault
•statusFlags
•tags
•valueSource
•valueSourceArray
