Objeto analogValue
Objeto analogValue
Defines a standardized object whose properties represent the externally visible characteristics of an analog value. An "analog value" is a control system parameter residing in the memory of the BACnet device.
Objetos do tipo analogValue possuem as seguintes propriedades:
•ackedTransitions
•commandTimeArray
•covIncrement
•currentCommandPriority
•deadband
•description
•eventAlgorithmInhibit
•eventAlgorithmInhibitRef
•eventDetectionEnable
•eventEnable
•eventMessageTexts
•eventMessageTextsConfig
•eventState
•eventTimeStamps
•faultHighLimit
•faultLowLimit
•highLimit
•lastCommandTime
•limitEnable
•lowLimit
•maxPresValue
•minPresValue
•notificationClass
•notifyType
•objectIdentifier
•objectName
•objectType
•outOfService
•presentValue
•priorityArray
•profileLocation
•profileName
•propertyList
•reliability
•reliabilityEvaluationInhibit
•relinquishDefault
•resolution
•statusFlags
•tags
•timeDelay
•timeDelayNormal
•units
•valueSource
•valueSourceArray
