Task Panel
Task Panel
The Task Panel contains the Displays and Connections tabs. The Displays tab lists all Displays and their respective Pens, according to the next figure.
Displays tab
Displays tab
Right-click a Display's name and select the Select columns option to select the columns to show on this tab, according to the next figure.
Legend window
Legend window
Available options on the Legend window
Option
Description
Available
Columns available for viewing. Please check the next table for more information about these columns
Add
Moves the selected column to the Selected list
Remove
Removes the selected column from the Selected list
Up
Moves the selected column one position up on the Selected list
Down
Moves the selected column one position down on the Selected list
Selected
Columns selected for viewing
NOTES
•To reorder the columns of a Legend, use the Up ou Down options.
•The available options for Legend columns, including their width, only apply to the selected Display.
•The value of the Average column corresponds to the average of values effectively shown on a Display, which may be different from the average of all values.
•The contextual menu of the Displays tab also contains the Auto Update, Show Grid Lines, Show Local Legend, and Interpolate options, described in details on topic Home Tab.
•For more information about the configuration of Pens, please check topic Pens.
The available columns for a Legend are described on the next table.
Available columns for a Legend
Column
Description
Average (Period)
Average of the period queried
Average (Visible)
Average of the visible period on a Display
EU
Engineering unit of a Pen's value
Last Query Duration
Elapsed time of the last query, in milliseconds
Last Query Status
Status of the last query
Max (Period)
Maximum value of a Pen in the period queried
Max (Visible)
Maximum value of a Pen in the visible period of the Display
Min (Period)
Minimum value of a Pen in the period queried
Min (Visible)
Minimum value of a Pen in the visible period of the Display
Pen Source
Source Tag of a Pen's data
Period End Time
Final date and time of the period queried
Period End Value
Final interpolated value of the period queried. Please check the next note for more information about the behavior of this column
Period Start Time
Initial date and time of the period queried
Period Start Value
Initial interpolated value of the period queried. Please check the next note for more information about the behavior of this column
Period Time Span
Time interval of the period queried
Period Value Span
Value interval of the period queried
Points Received
Total number of points received from the Pen
Quality
Quality of a Pen's value in the search point
Timestamp
Timestamp of a Pen's value in the search point
Value
Vertical Scale Max
Maximum value of the Vertical Scale
Vertical Scale Min
Minimum value of the Vertical Scale
Vertical Scale Title
Title of the Vertical Scale
NOTE
The Period Start Value and Period End Value columns have the following behavior:
•If the selected period does not have points with good quality, no value is displayed on these columns.
•If the selected period contains points with good quality crossing the Vertical Scale only at the beginning, the Period End Value column does not display any value.
•If the selected period contains points with good quality crossing the Vertical Scale only at the end, the Period Start Value does not display any value.
•If the selected period contains points with bad quality before or after the beginning or the end, the Period Start Value and Period End Value columns show the value of the real point closest to the Vertical Scale that represents the respective interval.
The Connections tab shows the available connections and their respective Pens, according to the next figure.
Connections tab
Connections tab
Right-clicking a Connection allows users to use the options described on the next table.
Available options for a Connection
Option
Description
Refresh
Updates data for this Connection
Edit
Allows editing this Connection's configurations. Please check topic Connections for more information about this option
Pen Filter
Opens the Pen Filter window, shown on the next figure, which allows filtering Pens of a Connection by name
Delete
Removes the selected Connection
Pen Filter window
Pen Filter window
Type the name of a Pen in the Filter field to start filtering by a Pen's name. For case-sensitive searches, select the Match case option. The window on the next figure shows an example of filtering.
Result of filtering Pens
Click OK to save the current filter, whose configuration is shown next to the Connection's name. To remove a filter, right-click a Connection's name and select the Delete Pen Filter option.
