Home Tab |
The Home tab is divided into the groups described next.
The available option on this group is Add Connection
and contains the items described on the next table.
Available items in the Add Connection option
Option |
Description |
E3 Database |
Allows a direct connection to a database created by Elipse E3, Elipse Power, or Elipse Water on a SQL Server or Oracle server, or else an Access database, which is a file with an .mdb extension |
SCADA |
Allows connecting to a database created by Elipse SCADA, which is a file with a .dat extension |
EPM |
Allows connecting to an EPM server |
E3 |
Allows connecting to an Elipse E3, Elipse Power, or Elipse Water server |
The available options on this group are described on the next table.
Available options on the Pointer Mode group
Option |
Description |
Select |
The Select mode allows selecting a specific Pen on a Display. The selected Pen is also automatically selected on Task Panel's Display tab |
Pan |
The Pan mode allows dragging Time and Vertical Scales without changing the zoom factor |
Zoom |
The Zoom mode allows selecting a Pen region with the mouse pointer, so that it becomes visible on the Display |
Search |
The Search mode allows viewing values from points on Pens or executing an interpolation. Please check topic Search Mode for more information about this option's behavior |
Available options on the Display group
Option |
Description |
Zoom Back |
Zoom operations are stored on a historical record and allow returning to previous zoom levels. The historical record of zoom operations is individual for each Display |
Fit |
Fits all Pens on the selected Display in the selected period of time |
Go To |
This options allows adjusting the Time Scale to pre-determined or custom periods. Please check topic Period Selection Mode for more information about this option's behavior |
Auto Update |
Allows the selected Display to perform its query again in pre-determined time periods. Please check topic Auto Update Mode for more information about this option's behavior |
Show Grid Lines |
Enables viewing grid lines on a Display's Plot Area |
Show Local Legend |
Enables viewing the name of Pens and their respective colors on a Display's Plot Area |
Interpolate |
Enables interpolating data on a Display |
NOTE |
The Auto Update, Show Grid Lines, Show Local Legend, and Interpolate options are also available on the contextual menu of Displays on the Displays tab of the Task Panel. |
