Keyboard Shortcuts |
The next table contains the available shortcut keys on TrendAnalysis.
Available shortcut keys on TrendAnalysis
Shortcut Key |
Description |
0 (zero) |
Fits the selected axis, vertical or horizontal |
Application or menu key |
Opens the contextual menu of the selected item on the Displays, Bookmarks, and Connections tabs |
CTRL + 0 (zero) |
Fits the horizontal and vertical axes |
CTRL + DELETE |
Removes a search point from a Display |
CTRL + F6 |
Browse through the pens of the selected vertical axis |
CTRL + G |
Displays or hides the grid of a Display |
CTRL + INS |
Inserts a search point on the center of the screen, using the last search configuration from the current session or using the Nearest Label mode if no search was performed |
CTRL + K |
Allows the mouse pointer to remain fixed on the screen during a search |
CTRL + Left arrow |
Moves the search point to the left |
CTRL + Minus sign (-) |
Executes a zoom out operation on the time axis |
CTRL + Plus sign (+) |
Executes a zoom in operation on the time axis |
CTRL + Right arrow |
Moves the search point to the right |
CTRL + T |
Displays or hides the Task Panel |
CTRL + TAB |
Toggles the focus between the Task Panel and the Displays |
CTRL + Z |
Executes a zoom back operation, when available |
DELETE |
Removes a plot area if there is no Vertical Scale selected. Otherwise, removes the Vertical Scale from the associated area |
Down arrow |
Moves down the selected axis |
END |
Moves to the current period of time |
ENTER |
Selects the current Display or pen on the Task Panel |
ESC |
Clears the current selection |
F5 |
Updates all connections on the Connections tab |
F6 |
Allows selecting axes individually |
F11 |
H |
Displays or hides the Display selected on the Task Panel |
INS |
Adds a plot are if there is no Vertical Scale selected. Otherwise, adds a new Vertical Scale to the associated area |
L |
Adds or removes the group from a Display |
Left arrow |
Moves to the previous point on the time scale |
Minus sign (-) |
Executes a zoom out operation on the selected vertical axis |
Mouse wheel |
Scrolls the Display area vertically or horizontally |
PAGE DOWN |
Changes the time scale of a chart to larger units, such as from hours to minutes |
PAGE UP |
Changes the time scale of a chart to smaller units, such as from minutes to hours |
Plus sign (+) |
Executes a zoom in operation on the selected vertical axis |
Right arrow |
Moves to the next point on the time scale |
SHIFT + TAB |
Browse through the Displays, counterclockwise |
Space bar |
Plays or pauses a Display |
TAB |
Browse through the Displays, clockwise |
Up arrow |
Moves up the selected axis |
