Connections Tab |
The Connections tab shows the connection with Elipse E3 and the available Tags for use on Displays. To add a Pen, drag it to the Display area or right-click a Tag and select the Insert option. To update the list of Tags of a connection, right-click the name of that connection and select the Refresh option.
NOTE |
Viewers from versions prior to version 6.5 do not have access to remote Tags. |
