Interface Tags on Extra ISOTCP Connections |
By opting to use extra ISOTCP connections with the Extra Connections parameter on the Driver's configuration window, these connections can be controlled and monitored by Interface-specific Tags Physical Layer Status, IPSelect, and IPSwitch.
NOTE |
These Tags cannot be used when the Extra Connections parameter is equal to 0 (zero). In this case, use the corresponding IOKit Tags, with the same name, whose usage can be checked on topic Documentation of I/O Interfaces. |
