IPSelect (MProt)
IPSelect (MProt)
Reading or Writing
Configuration by numerical parameters
Parameter
Value
N1
-2 (minus two)
N2
0 (zero)
N3
4 (four)
N4
0 (zero)
Configuration by syntactical parameters
Parameter
Value
Item
MProt.IO.Ethernet.IPSelect
Indicates the active IP address. Possible values are 0: The main IP address is selected or active or 1: The alternative or backup IP address is selected or active.
If the Ethernet interface is connected, this Tag indicates which one of the two configured IP addresses is in use. If the interface is disconnected, this Tag indicates which IP address is used first in the next attempt to connect.
During the connection process, if the active IP address is not available, then the IOKit library tries to connect to the other IP address. If the connection to that alternative IP address succeeds, then that IP address is set as the active one, that is, an automatic switchover.
To force a manual switchover, write 1 (one) or 0 (zero) to this Tag. This forces a reconnection with the specified IP address (0: Main IP address or 1: Backup IP address) if this Driver is currently connected. If this Driver is disconnected, that configures the active IP address for the next connection attempt.
