IPSwitch (MProt) |
Configuration by numerical parameters
Parameter |
N1 |
-2 (minus two) |
N2 |
0 (zero) |
N3 |
4 (four) |
N4 |
1 (one) |
Configuration by syntactical parameters
Parameter |
Item |
MProt.IO.Ethernet.IPSwitch |
Writing any value to this Tag forces a manual switchover. If the main IP address is active, then the backup IP address is activated, and vice versa. This forces a reconnection to the specified IP address if this Driver is currently connected. If this Driver is disconnected, that configures the active IP address for the next connection attempt.
