Physical Layer Status (MProt) |
Configuration by numerical parameters
Parameter |
N1 |
-2 (minus two) |
N2 |
0 (zero) |
N3 |
0 (zero) |
N4 |
2 (two) |
Configuration by syntactical parameters
Parameter |
Item |
MProt.IO.PhysicalLayerStatus |
This Tag indicates the status of the connection on the physical layer. Possible values are 0: Physical layer disconnected or 1: Physical layer connected.
