Inserting a Driver |
If using Elipse E3, Elipse Power, or Elipse Water, please check topic Adding a Driver to an Elipse Software Application - Elipse E3, Elipse Power, or Elipse Water.
If using Elipse SCADA, please check topic Adding a Driver to an Elipse Software Application - Elipse SCADA.
Then, check the next step on this Manual, which shows how to configure this Driver using its configuration window for the most common cases.
