Quick Configuration Guide |
This topic describes all necessary steps to configure this Driver for communication with devices compliant with the standard protocol defined by the Modbus Organization, considering the most common configuration options.
If a device is fully compliant with the standard protocol, and users only want to read or write registers or bits, the topics Inserting a Driver, Configuring a Driver, and Configuring I/O Tags are probably sufficient to configure this Driver.
