SequenceOfBACnetRelationship
This XML representation of complex data is used by the following objects/properties:
•structuredView.subordinateRelationships
XML Schema
  <xs:complexType name="SequenceOfBACnetRelationship">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetRelationship" type="BACnetRelationship" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetRelationship" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetRelationship />
</Value>
Example 2:
  <SequenceOfBACnetRelationship>
    <BACnetRelationship>unknown</BACnetRelationship>
    <BACnetRelationship>default</BACnetRelationship>
    <BACnetRelationship>contains</BACnetRelationship>
  </SequenceOfBACnetRelationship>
</Value>
