structuredView.subordinateRelationships |
Describes the relationship to each member of the Subordinate_List. If this property is absent, then relationship to each of the subordinates is equal to the value of the Default_Subordinate_Relationship property, if present, else equal to UNKNOWN. If the size of this array is changed, the size of the Subordinate_List, Subordinate_Annotations, Subordinate_Tags, and Subordinate_Node_Types arrays, if present, shall also be changed to the same size. Uninitialized Subordinate_Relationships array elements shall be equal to DEFAULT.
Property subordinateRelationships of object structuredView can be read and written using a single IOTag.
structuredView-<objectAddress>.subordinateRelationships |
<type> = 29 |
<property> = 489 |
A character string containing an XML with a value of type <SequenceOfBACnetRelationship>.
