BACnetRelationship |
<xs:simpleType name="BACnetRelationship">
<xs:enumeration value="unknown" />
<xs:enumeration value="default" />
<xs:enumeration value="contains" />
<xs:enumeration value="containedBy" />
<xs:enumeration value="uses" />
<xs:enumeration value="usedBy" />
<xs:enumeration value="commands" />
<xs:enumeration value="commandedBy" />
<xs:enumeration value="adjusts" />
<xs:enumeration value="adjustedBy" />
<xs:enumeration value="ingress" />
<xs:enumeration value="egress" />
<xs:enumeration value="suppliesAir" />
<xs:enumeration value="receivesAir" />
<xs:enumeration value="suppliesHotAir" />
<xs:enumeration value="receivesHotAir" />
<xs:enumeration value="suppliesCoolAir" />
<xs:enumeration value="receivesCoolAir" />
<xs:enumeration value="suppliesPower" />
<xs:enumeration value="receivesPower" />
<xs:enumeration value="suppliesGas" />
<xs:enumeration value="receivesGas" />
<xs:enumeration value="suppliesWater" />
<xs:enumeration value="receivesWater" />
<xs:enumeration value="suppliesHotWater" />
<xs:enumeration value="receivesHotWater" />
<xs:enumeration value="suppliesCoolWater" />
<xs:enumeration value="receivesCoolWater" />
<xs:enumeration value="suppliesSteam" />
<xs:enumeration value="receivesSteam" />
</xs:restriction>
</xs:simpleType>
Example 1:
<BACnetRelationship>unknown</BACnetRelationship>
