SequenceOfBACnetObjectIdentifier
This XML representation of complex data is used by the following objects/properties:
•device.configurationFiles
•device.objectList
•device.structuredObjectList
•elevatorGroup.groupMembers
XML Schema
  <xs:complexType name="SequenceOfBACnetObjectIdentifier">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetObjectIdentifier" type="BACnetObjectIdentifier" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetObjectIdentifier" />
</xs:schema>
Examples
Example 1:
  <SequenceOfBACnetObjectIdentifier />
</Value>
Example 2:
  <SequenceOfBACnetObjectIdentifier>
    <BACnetObjectIdentifier>device-501</BACnetObjectIdentifier>
    <BACnetObjectIdentifier>device-502</BACnetObjectIdentifier>
    <BACnetObjectIdentifier>device-503</BACnetObjectIdentifier>
  </SequenceOfBACnetObjectIdentifier>
</Value>
