device.configurationFiles |
Entries in this array identify the files within the device that define the device's image that can be backed up. The content of this property is only required to be valid during the backup procedure.
Property configurationFiles of object device can be read and written using a single IOTag.
device-<objectAddress>.configurationFiles |
<type> = 8 |
<property> = 154 |
A character string containing an XML with a value of type <SequenceOfBACnetObjectIdentifier>.
