device.structuredObjectList |
Contains references to objects chosen for use as starting points for the traversal of object hierarchies.
Property structuredObjectList of object device can be read and written using a single IOTag.
device-<objectAddress>.structuredObjectList |
<type> = 8 |
<property> = 209 |
A character string containing an XML with a value of type <SequenceOfBACnetObjectIdentifier>.
