BACnetSecurityKeySet
This XML representation of complex data is used by the following objects/properties:
•networkSecurity.keySets
XML Schema
  <xs:complexType name="BACnetSecurityKeySet">
    <xs:sequence>
      <xs:element name="KeyRevision" type="Unsigned8" />
      <xs:element name="ActivationTime" type="BACnetDateTime" />
      <xs:element name="ExpirationTime" type="BACnetDateTime" />
      <xs:element name="KeyIds" type="SequenceOfBACnetKeyIdentifier" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetSecurityKeySet" />
</xs:schema>
Examples
Example 1:
  <BACnetSecurityKeySet>
    <KeyRevision>33</KeyRevision>
    <ActivationTime>
      <Date>2018-12-20</Date>
      <Time>22:39:15.980</Time>
    </ActivationTime>
    <ExpirationTime>
      <Date>2019-12-20</Date>
    </ExpirationTime>
    <KeyIds />
  </BACnetSecurityKeySet>
</Value>
Example 2:
    <KeyRevision>36</KeyRevision>
    <ActivationTime>
      <Date>2021-12-20</Date>
    </ActivationTime>
    <ExpirationTime>
      <Date>2022-12-20</Date>
    </ExpirationTime>
    <KeyIds>
      <BACnetKeyIdentifier>
        <Algorithm>39</Algorithm>
        <KeyId>40</KeyId>
      </BACnetKeyIdentifier>
        <Algorithm>41</Algorithm>
        <KeyId>42</KeyId>
        <Algorithm>43</Algorithm>
        <KeyId>44</KeyId>
    </KeyIds>
</Value>
