Unsigned8
Unsigned8
This XML representation of complex data is used by the following objects/properties:
•elevatorGroup.landingCallControl
XML Schema
  <xs:simpleType name="Unsigned8">
    <xs:restriction base="xs:unsignedByte" />
  </xs:simpleType>
  <xs:element name="Value" type="Unsigned8" />
</xs:schema>
Examples
Example 1:
  <Unsigned8>33</Unsigned8>
</Value>
