elevatorGroup.landingCallControl
A write to this property is equivalent to a passenger pressing a call button at a landing, indicating either desired direction of travel or destination floor.
Property landingCallControl of object elevatorGroup can be read and written using a block tag with 3 elements.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
elevatorGroup-<objectAddress>.landingCallControl
Size
3 elements
Numeric Parameters
Property
Value
B1:
<deviceAddress>
B2:
<type> = 57
B3:
<objectAddress>
B4:
<property> = 471
Size:
3 elements
Block Elements
Index
Name
Type
0
FloorNumber
An 8-bit integer value ranging from 0 to 255.
1
Command
•An integer representing one of the options of enumeration <BACnetLiftCarDirection>.
•A character string containing an XML with a value of type <Unsigned8>.
2
FloorText
A string value.
OBS: this is an optional element, a <null> value indicates the element is not present.
