file Object
file Object
Defines a standardized object that is used to describe properties of data files that may be accessed using File Services.
Objects of type file have the following properties:
•archive
•description
•fileAccessMethod
•fileSize
•fileType
•modificationDate
•objectIdentifier
•objectName
•objectType
•profileLocation
•profileName
•propertyList
•readOnly
•recordCount
•tags
