file.objectIdentifier |
Property objectIdentifier of object file can be read and written using a single IOTag.
file-<objectAddress>.objectIdentifier |
<type> = 10 |
<property> = 75 |
A string value containing a BACnet Object Identifier in the syntax '<Type>-<Address>' (ex: 'analogOutput-345').
