file.fileAccessMethod |
Indicates the type(s) of file access supported for this object. 0 = record access, 1 = stream access, 2 = record and stream access
Property fileAccessMethod of object file can be read and written using a single IOTag.
file-<objectAddress>.fileAccessMethod |
<type> = 10 |
<property> = 41 |
An integer representing one of the options of enumeration <BACnetFileAccessMethod>.
