file.readOnly |
Indicates whether (FALSE) or not (TRUE) the file data may be changed through the use of a BACnet AtomicWriteFile service.
Property readOnly of object file can be read and written using a single IOTag.
file-<objectAddress>.readOnly |
<type> = 10 |
<property> = 99 |
