command Object
command Object
Defines a standardized object whose properties represent the externally visible characteristics of a multi-action command procedure. A Command object is used to write a set of values to a group of object properties, based on the "action code" that is written to the Present_Value of the Command object. Whenever the Present_Value property of the Command object is written to, it triggers the Command object to take a set of actions that change the values of a set of other objects' properties.
Objects of type command have the following properties:
•ackedTransitions
•action
•actionText
•allWritesSuccessful
•description
•eventDetectionEnable
•eventEnable
•eventMessageTexts
•eventMessageTextsConfig
•eventState
•eventTimeStamps
•inProcess
•notificationClass
•notifyType
•objectIdentifier
•objectName
•objectType
•presentValue
•profileLocation
•profileName
•propertyList
•reliability
•reliabilityEvaluationInhibit
•statusFlags
•tags
•valueSource
