command.allWritesSuccessful |
Indicates the success or failure of the sequence of actions that are triggered when the presentValue property is written to.
Property allWritesSuccessful of object command can be read and written using a single IOTag.
command-<objectAddress>.allWritesSuccessful |
<type> = 7 |
<property> = 9 |
