command.action |
Specifies an array of 'action lists'.
Property action of object command can be read and written using a single IOTag.
command-<objectAddress>.action |
<type> = 7 |
<property> = 2 |
A character string containing an XML with a value of type <SequenceOfBACnetActionList>.
