SequenceOfBACnetPropertyAccessResult
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•globalGroup.presentValue
Esquema XML
  <xs:complexType name="SequenceOfBACnetPropertyAccessResult">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetPropertyAccessResult" type="BACnetPropertyAccessResult" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetPropertyAccessResult" />
</xs:schema>
Exemplos
Exemplo 1:
  <SequenceOfBACnetPropertyAccessResult />
</Value>
Exemplo 2:
  <SequenceOfBACnetPropertyAccessResult>
    <BACnetPropertyAccessResult>
      <ObjectIdentifier>device-501</ObjectIdentifier>
      <PropertyIdentifier>ackRequired</PropertyIdentifier>
      <PropertyArrayIndex>1236</PropertyArrayIndex>
      <DeviceIdentifier>device-504</DeviceIdentifier>
      <AccessResult>
        <PropertyValue>
          <Boolean>true</Boolean>
        </PropertyValue>
      </AccessResult>
    </BACnetPropertyAccessResult>
      <ObjectIdentifier>device-505</ObjectIdentifier>
      <PropertyIdentifier>activeVtSessions</PropertyIdentifier>
      <PropertyArrayIndex>1240</PropertyArrayIndex>
      <DeviceIdentifier>device-508</DeviceIdentifier>
      <AccessResult>
        <PropertyValue>
          <BACnetVTSession>
            <LocalVtSessionId>41</LocalVtSessionId>
            <RemoteVtSessionId>42</RemoteVtSessionId>
            <RemoteVtAddress>
              <NetworkNumber>7644</NetworkNumber>
              <MacAddress>FF</MacAddress>
            </RemoteVtAddress>
          </BACnetVTSession>
        </PropertyValue>
      </AccessResult>
      <ObjectIdentifier>device-512</ObjectIdentifier>
      <PropertyIdentifier>applicationSoftwareVersion</PropertyIdentifier>
      <PropertyArrayIndex>1247</PropertyArrayIndex>
      <DeviceIdentifier>device-515</DeviceIdentifier>
      <AccessResult>
        <PropertyValue>
          <CharacterString>Abcde</CharacterString>
        </PropertyValue>
      </AccessResult>
  </SequenceOfBACnetPropertyAccessResult>
</Value>
