SequenceOfBACnetNameValue
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•accessCredential.tags
•accessDoor.tags
•accessPoint.tags
•accessRights.tags
•accessUser.tags
•accessZone.tags
•accumulator.tags
•alertEnrollment.tags
•analogInput.tags
•analogOutput.tags
•analogValue.tags
•averaging.tags
•binaryInput.tags
•binaryLightingOutput.tags
•binaryOutput.tags
•binaryValue.tags
•bitstringValue.tags
•calendar.tags
•channel.tags
•characterstringValue.tags
•command.tags
•credentialDataInput.tags
•dateValue.tags
•datepatternValue.tags
•datetimeValue.tags
•datetimepatternValue.tags
•device.tags
•elevatorGroup.tags
•escalator.tags
•eventEnrollment.tags
•eventLog.tags
•file.tags
•globalGroup.tags
•group.tags
•integerValue.tags
•largeAnalogValue.tags
•lifeSafetyPoint.tags
•lifeSafetyZone.tags
•lift.tags
•lightingOutput.tags
•loadControl.tags
•loop.tags
•multiStateInput.tags
•multiStateOutput.tags
•multiStateValue.tags
•networkPort.tags
•networkSecurity.tags
•notificationClass.tags
•notificationForwarder.tags
•octetstringValue.tags
•positiveIntegerValue.tags
•program.tags
•pulseConverter.tags
•schedule.tags
•structuredView.tags
•timeValue.tags
•timepatternValue.tags
•timer.tags
•trendLog.tags
•trendLogMultiple.tags
Esquema XML
  <xs:complexType name="SequenceOfBACnetNameValue">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetNameValue" type="BACnetNameValue" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetNameValue" />
</xs:schema>
Exemplos
Exemplo 1:
  <SequenceOfBACnetNameValue />
</Value>
Exemplo 2:
  <SequenceOfBACnetNameValue>
    <BACnetNameValue>
      <Name>Abcde</Name>
      <Value>
        <Boolean>true</Boolean>
      </Value>
    </BACnetNameValue>
    <BACnetNameValue>
      <Name>Abcde</Name>
      <Value>
      </Value>
    </BACnetNameValue>
    <BACnetNameValue>
      <Name>Abcde</Name>
      <Value>
      </Value>
    </BACnetNameValue>
  </SequenceOfBACnetNameValue>
</Value>
