SequenceOfBACnetLifeSafetyMode
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•lifeSafetyPoint.acceptedModes
•lifeSafetyZone.acceptedModes
Esquema XML
  <xs:complexType name="SequenceOfBACnetLifeSafetyMode">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetLifeSafetyMode" type="BACnetLifeSafetyMode" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetLifeSafetyMode" />
</xs:schema>
Exemplos
Exemplo 1:
  <SequenceOfBACnetLifeSafetyMode />
</Value>
Exemplo 2:
  <SequenceOfBACnetLifeSafetyMode>
    <BACnetLifeSafetyMode>off</BACnetLifeSafetyMode>
    <BACnetLifeSafetyMode>on</BACnetLifeSafetyMode>
    <BACnetLifeSafetyMode>test</BACnetLifeSafetyMode>
  </SequenceOfBACnetLifeSafetyMode>
</Value>
