SequenceOfBACnetLandingDoorStatus
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•lift.landingDoorStatus
Esquema XML
  <xs:complexType name="SequenceOfBACnetLandingDoorStatus">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetLandingDoorStatus" type="BACnetLandingDoorStatus" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetLandingDoorStatus" />
</xs:schema>
Exemplos
Exemplo 1:
  <SequenceOfBACnetLandingDoorStatus />
</Value>
Exemplo 2:
  <SequenceOfBACnetLandingDoorStatus>
    <BACnetLandingDoorStatus>
      <LandingDoors />
    </BACnetLandingDoorStatus>
      <LandingDoors>
        <LandingDoors_Item>
          <FloorNumber>33</FloorNumber>
          <DoorStatus>opened</DoorStatus>
        </LandingDoors_Item>
      </LandingDoors>
      <LandingDoors>
        <LandingDoors_Item>
          <FloorNumber>35</FloorNumber>
          <DoorStatus>doorFault</DoorStatus>
      </LandingDoors>
  </SequenceOfBACnetLandingDoorStatus>
</Value>
Exemplo 3:
      <LandingDoors>
        <LandingDoors_Item>
          <FloorNumber>37</FloorNumber>
          <DoorStatus>none</DoorStatus>
        <LandingDoors_Item>
          <FloorNumber>39</FloorNumber>
          <DoorStatus>opening</DoorStatus>
        <LandingDoors_Item>
          <FloorNumber>41</FloorNumber>
          <DoorStatus>limitedOpened</DoorStatus>
      </LandingDoors>
      <LandingDoors>
        <LandingDoors_Item>
          <FloorNumber>43</FloorNumber>
      </LandingDoors>
      <LandingDoors>
        <LandingDoors_Item>
          <FloorNumber>45</FloorNumber>
      </LandingDoors>
</Value>
