lift.landingDoorStatus |
Represents the status of the landing doors on the floors served by this lift. Each element of this array represents the list of landing doors for the door of the car assigned to this array element. A landing door status includes the universal floor number and the currently active door status for the landing door.
A propriedade landingDoorStatus do objeto lift pode ser lida e escrita utilizando um tag normal (IOTag).
lift-<endereçoDoObjeto>.landingDoorStatus |
<tipo> = 59 |
<propriedade> = 472 |
Um string contendo um XML com um valor do tipo <SequenceOfBACnetLandingDoorStatus>.
