SequenceOfBACnetAuthenticationFactorFormat
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•credentialDataInput.supportedFormats
Esquema XML
  <xs:complexType name="SequenceOfBACnetAuthenticationFactorFormat">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetAuthenticationFactorFormat" type="BACnetAuthenticationFactorFormat" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetAuthenticationFactorFormat" />
</xs:schema>
Exemplos
Exemplo 1:
  <SequenceOfBACnetAuthenticationFactorFormat />
</Value>
Exemplo 2:
  <SequenceOfBACnetAuthenticationFactorFormat>
    <BACnetAuthenticationFactorFormat>
      <FormatType>undefined</FormatType>
      <VendorId>7635</VendorId>
      <VendorFormat>7636</VendorFormat>
    </BACnetAuthenticationFactorFormat>
      <FormatType>simpleNumber16</FormatType>
      <VendorId>7638</VendorId>
      <VendorFormat>7639</VendorFormat>
      <FormatType>simpleAlphaNumeric</FormatType>
      <VendorId>7641</VendorId>
      <VendorFormat>7642</VendorFormat>
  </SequenceOfBACnetAuthenticationFactorFormat>
</Value>
