SequenceOfBACnetAssignedAccessRights
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•accessCredential.assignedAccessRights
Esquema XML
  <xs:complexType name="SequenceOfBACnetAssignedAccessRights">
    <xs:sequence>
      <xs:element minOccurs="0" maxOccurs="unbounded" name="BACnetAssignedAccessRights" type="BACnetAssignedAccessRights" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="SequenceOfBACnetAssignedAccessRights" />
</xs:schema>
Exemplos
Exemplo 1:
  <SequenceOfBACnetAssignedAccessRights />
</Value>
Exemplo 2:
  <SequenceOfBACnetAssignedAccessRights>
    <BACnetAssignedAccessRights>
      <AssignedAccessRights>
        <DeviceIdentifier>device-501</DeviceIdentifier>
        <ObjectIdentifier>device-502</ObjectIdentifier>
      </AssignedAccessRights>
      <Enable>true</Enable>
    </BACnetAssignedAccessRights>
        <DeviceIdentifier>device-503</DeviceIdentifier>
        <ObjectIdentifier>device-504</ObjectIdentifier>
        <DeviceIdentifier>device-505</DeviceIdentifier>
        <ObjectIdentifier>device-506</ObjectIdentifier>
  </SequenceOfBACnetAssignedAccessRights>
</Value>
