BACnetLightingCommand
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•channel.presentValue
•timer.stateChangeValues
Esquema XML
  <xs:complexType name="BACnetLightingCommand">
    <xs:sequence>
      <xs:element name="Operation" type="BACnetLightingOperation" />
      <xs:element minOccurs="0" name="TargetLevel" type="REAL" />
      <xs:element minOccurs="0" name="RampRate" type="REAL" />
      <xs:element minOccurs="0" name="StepIncrement" type="REAL" />
      <xs:element minOccurs="0" name="FadeTime" type="Unsigned" />
      <xs:element minOccurs="0" name="Priority" type="Unsigned" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetLightingCommand" />
</xs:schema>
Exemplos
Exemplo 1:
  <BACnetLightingCommand>
    <Operation>none</Operation>
    <TargetLevel>1235.567749</TargetLevel>
    <RampRate>1236.567749</RampRate>
    <StepIncrement>1237.567749</StepIncrement>
    <FadeTime>1238</FadeTime>
    <Priority>1239</Priority>
  </BACnetLightingCommand>
</Value>
Exemplo 2:
    <Operation>stepOff</Operation>
</Value>
