BACnetEventParameter_Extended
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•eventEnrollment.eventParameters
Esquema XML
  <xs:complexType name="BACnetEventParameter_Extended">
    <xs:sequence>
      <xs:element name="VendorId" type="Unsigned16" />
      <xs:element name="ExtendedEventType" type="Unsigned" />
      <xs:element name="Parameters" type="SequenceOfBACnetEventParameter_Extended_Unnamed" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetEventParameter_Extended" />
</xs:schema>
Exemplos
Exemplo 1:
  <BACnetEventParameter_Extended>
    <VendorId>7634</VendorId>
    <ExtendedEventType>1235</ExtendedEventType>
    <Parameters />
  </BACnetEventParameter_Extended>
</Value>
Exemplo 2:
    <VendorId>7636</VendorId>
    <ExtendedEventType>1237</ExtendedEventType>
    <Parameters>
      <Unnamed>
        <Null />
      </Unnamed>
      <Unnamed>
        <Null />
      </Unnamed>
      <Unnamed>
        <Null />
      </Unnamed>
    </Parameters>
</Value>
