BACnetEventParameter_ChangeOfTimer
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•eventEnrollment.eventParameters
Esquema XML
  <xs:complexType name="BACnetEventParameter_ChangeOfTimer">
    <xs:sequence>
      <xs:element name="TimeDelay" type="Unsigned" />
      <xs:element name="AlarmValues" type="SequenceOfBACnetTimerState" />
      <xs:element name="UpdateTimeReference" type="BACnetDeviceObjectPropertyReference" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetEventParameter_ChangeOfTimer" />
</xs:schema>
Exemplos
Exemplo 1:
  <BACnetEventParameter_ChangeOfTimer>
    <TimeDelay>1234</TimeDelay>
    <AlarmValues />
    <UpdateTimeReference>
      <ObjectIdentifier>device-502</ObjectIdentifier>
      <PropertyIdentifier>action</PropertyIdentifier>
      <PropertyArrayIndex>1237</PropertyArrayIndex>
      <DeviceIdentifier>device-505</DeviceIdentifier>
    </UpdateTimeReference>
  </BACnetEventParameter_ChangeOfTimer>
</Value>
Exemplo 2:
    <TimeDelay>1239</TimeDelay>
    <AlarmValues>
      <BACnetTimerState>idle</BACnetTimerState>
      <BACnetTimerState>running</BACnetTimerState>
      <BACnetTimerState>expired</BACnetTimerState>
    </AlarmValues>
      <ObjectIdentifier>device-510</ObjectIdentifier>
      <PropertyIdentifier>apduSegmentTimeout</PropertyIdentifier>
      <PropertyArrayIndex>1245</PropertyArrayIndex>
      <DeviceIdentifier>device-513</DeviceIdentifier>
</Value>
