BACnetEventParameter_ChangeOfLifeSafety
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•eventEnrollment.eventParameters
Esquema XML
  <xs:complexType name="BACnetEventParameter_ChangeOfLifeSafety">
    <xs:sequence>
      <xs:element name="TimeDelay" type="Unsigned" />
      <xs:element name="ListOfLifeSafetyAlarmValues" type="SequenceOfBACnetLifeSafetyState" />
      <xs:element name="ListOfAlarmValues" type="SequenceOfBACnetLifeSafetyState" />
      <xs:element name="ModePropertyReference" type="BACnetDeviceObjectPropertyReference" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetEventParameter_ChangeOfLifeSafety" />
</xs:schema>
Exemplos
Exemplo 1:
  <BACnetEventParameter_ChangeOfLifeSafety>
    <TimeDelay>1234</TimeDelay>
    <ListOfLifeSafetyAlarmValues />
    <ListOfAlarmValues />
    <ModePropertyReference>
      <ObjectIdentifier>device-502</ObjectIdentifier>
      <PropertyIdentifier>action</PropertyIdentifier>
      <PropertyArrayIndex>1237</PropertyArrayIndex>
      <DeviceIdentifier>device-505</DeviceIdentifier>
    </ModePropertyReference>
  </BACnetEventParameter_ChangeOfLifeSafety>
</Value>
Exemplo 2:
    <TimeDelay>1239</TimeDelay>
    <ListOfAlarmValues>
      <BACnetLifeSafetyState>notReady</BACnetLifeSafetyState>
      <BACnetLifeSafetyState>active</BACnetLifeSafetyState>
      <BACnetLifeSafetyState>tamper</BACnetLifeSafetyState>
    </ListOfAlarmValues>
      <ObjectIdentifier>device-510</ObjectIdentifier>
      <PropertyIdentifier>apduSegmentTimeout</PropertyIdentifier>
      <PropertyArrayIndex>1245</PropertyArrayIndex>
      <DeviceIdentifier>device-513</DeviceIdentifier>
</Value>
Exemplo 3:
    <TimeDelay>1247</TimeDelay>
    <ListOfLifeSafetyAlarmValues>
      <BACnetLifeSafetyState>duress</BACnetLifeSafetyState>
      <BACnetLifeSafetyState>tamperAlarm</BACnetLifeSafetyState>
      <BACnetLifeSafetyState>abnormal</BACnetLifeSafetyState>
    </ListOfLifeSafetyAlarmValues>
      <ObjectIdentifier>device-518</ObjectIdentifier>
      <PropertyIdentifier>controlledVariableReference</PropertyIdentifier>
      <PropertyArrayIndex>1253</PropertyArrayIndex>
      <DeviceIdentifier>device-521</DeviceIdentifier>
</Value>
Exemplo 4:
    <TimeDelay>1255</TimeDelay>
      <BACnetLifeSafetyState>supervisory</BACnetLifeSafetyState>
      <BACnetLifeSafetyState>testSupervisory</BACnetLifeSafetyState>
      <BACnetLifeSafetyState>quiet</BACnetLifeSafetyState>
    <ListOfAlarmValues>
      <BACnetLifeSafetyState>preAlarm</BACnetLifeSafetyState>
      <BACnetLifeSafetyState>alarm</BACnetLifeSafetyState>
      <BACnetLifeSafetyState>fault</BACnetLifeSafetyState>
      <ObjectIdentifier>device-529</ObjectIdentifier>
      <PropertyIdentifier>deviceAddressBinding</PropertyIdentifier>
      <PropertyArrayIndex>1264</PropertyArrayIndex>
      <DeviceIdentifier>device-532</DeviceIdentifier>
</Value>
