BACnetEventParameter_AccessEvent
Esta representação de dados complexos via XML é utilizada pelos seguintes objetos/propriedades:
•eventEnrollment.eventParameters
Esquema XML
  <xs:complexType name="BACnetEventParameter_AccessEvent">
    <xs:sequence>
      <xs:element name="ListOfAccessEvents" type="SequenceOfBACnetAccessEvent" />
      <xs:element name="AccessEventTimeReference" type="BACnetDeviceObjectPropertyReference" />
    </xs:sequence>
  </xs:complexType>
  <xs:element name="Value" type="BACnetEventParameter_AccessEvent" />
</xs:schema>
Exemplos
Exemplo 1:
  <BACnetEventParameter_AccessEvent>
    <ListOfAccessEvents />
    <AccessEventTimeReference>
      <ObjectIdentifier>device-501</ObjectIdentifier>
      <PropertyIdentifier>ackRequired</PropertyIdentifier>
      <PropertyArrayIndex>1236</PropertyArrayIndex>
      <DeviceIdentifier>device-504</DeviceIdentifier>
    </AccessEventTimeReference>
  </BACnetEventParameter_AccessEvent>
</Value>
Exemplo 2:
    <ListOfAccessEvents>
      <BACnetAccessEvent>duress</BACnetAccessEvent>
      <BACnetAccessEvent>trace</BACnetAccessEvent>
      <BACnetAccessEvent>lockoutMaxAttempts</BACnetAccessEvent>
    </ListOfAccessEvents>
      <ObjectIdentifier>device-508</ObjectIdentifier>
      <PropertyIdentifier>all</PropertyIdentifier>
      <PropertyArrayIndex>1243</PropertyArrayIndex>
      <DeviceIdentifier>device-511</DeviceIdentifier>
</Value>
