This section contains information about the properties of a Discrete Alarm Source (DiscreteAlarm) object. This object does not contain events nor methods associated to it.
NOTE
When the value of the Event property, common to all Alarm Sources, is set to True, the Kind property of objects belonging to the collection of Sub-conditions of a Discrete Alarm Source cannot be modified, that is, all alarm sub-conditions behave as events.
Feedback
Would you like to provide more information about your experience in this site?
