Kind |
Indicates this Subcondition's behavior. Possible values for this property are 0: Alarm (default), 1: Event, or 2: Return. If the Event property, common to all Alarm Sources, is set to True, this property cannot be modified, and its value always remains in 1 (one, Event). This property cannot be changed while this object is active.
