Event |
When set to True, indicates that this is an Event-type Alarm. An Event-type Alarm, when activated, is acknowledged by the "System" user. Therefore, when it is acknowledged nothing happens, that is, it has no effect, as well as it does not increment the number of active Alarms nor the number of unacknowledged Alarms. This property cannot be changed while this object is active.
