Elipse Event Log Viewer
Elipse Event Log Viewer, from now on referred only as Log Viewer, views messages of a supervisory system stored on files in Event Trace Logfile (.etl) format. These logs store information about Elipse Software systems on user's computer.
Basically, processes store these messages on disk using pre-configured folders, which are created by the log system when it is started. A service executing on the system is responsible for managing the size of files on the log folder, as well as their lifespan. If this service is disabled or is not executing, users cannot perform a file management.
The main function of Log Viewer is to display system-generated messages to users, by using filter and search functions, making the task of searching for errors easier.
IMPORTANT
These logs are only enabled by users belonging to Windows Administrator or Performance Log Users groups. For more information, please check topic Security Restrictions.
Log Viewer presents the following features:
•Opens files in ETL format
•Opens more than one file at a time, merging the content of these files
•Searches for messages
•Filters messages by type and by time
•Views log sessions in use
•Exports events to files with tab-separated columns
•Configures view options
•Configures storage options of messages on disk
•Allows selecting and copying events to the Clipboard
To use Log Viewer, select the Log Viewer item on Windows Start menu to open a window similar to the one on the next figure.
Elipse Event Log Viewer's main window
This program is divided into an area on the left side to view files and an area on the right side to view events. Above these areas there is a toolbar and below there is a status bar. The available options on this toolbar are described on the next table.
Available options on the toolbar
Option
Description
Open Event File (CTRL + O) Open Event File
Opens a log file
Merge Event Files (CTRL + M) Merge Event Files
Opens several files and merges their events chronologically on the same view
Close File (CTRL + F4) Close File
Closes the selected file
Copy (CTRL + C) Copy
Copies the selected events to the Clipboard
Find (CTRL + F) Find
Opens a window to search for messages
Filter Editor (CTRL + I) Filter Editor
Shows a window to edit filters
Toggle filter ON/OFF (F6) Toggle filter ON/OFF
Turns on or off all filters on the events of the selected file
Refresh View (F5) Refresh View
Refreshes the view with the last events stored on disk. If there are events in memory, they are stored on disk before refreshing
Cancel Refresh (SHIFT + F5) Cancel Refresh
Cancels a view refresh with the files on disk
Edit Bookmarks (CTRL + SHIFT + E) Edit Bookmarks
Opens an edition window, which allows removing a bookmark, removing all bookmarks, or locating a bookmark
Add Fast Bookmark (CTRL + B) Add Fast Bookmark
Creates a bookmark with a default name Bookmarkn, where n is an automatically incremented number
Add Bookmark (CTRL + A) Add Bookmark
Creates a bookmark, by opening a window to select its name
Remove Bookmark (CTRL + R) Remove Bookmark
Removes the selected bookmark
Previous Bookmark (SHIFT + F2) Previous Bookmark
Selects the previous bookmark
Next Bookmark (F2) Next Bookmark
Selects the next bookmark
Running Loggers (CTRL + S) Running Loggers
Shows all active log sessions on the system
Collect Files (F8) Collect Files
Opens the Elipse Event Log Collector's window
Export Events (CTRL + E) Export Events
Opens the Elipse Event Log Export's window
Storage Settings (CTRL + T) Storage Settings
Displays the file storage configuration window
Post-Filtering by Category Post-Filtering by Category
Allows selecting a category to sort messages. To toggle between existing categories, use the shortcut keys SHIFT + F6 to select the previous category and CTRL + F6 to select the next category
Help (F1) Help
Opens Elipse Event Log User's Manual
The available categories for message sorting are described on the next table.
Available categories for message sorting
Number
Category
Color
0 (zero)
Log header
Green
10
Error
Red
11
Warning
Yellow
12
Information
Blue
14
Message for general usage
15
Statistical and performance data
16
Trace
17
Additional information about a module
Purple
The status bar of Log Viewer's main window is divided into the areas shown on the next table.
Areas of Log Viewer's status bar
Area
Description
Number of events
Number of events of the selected file on the viewing area. If there is no file open, it displays the text "Ready". In case there is any active filter, the displayed value refers to events visible after applying that filter. In case of loss of events, displays the total number of events lost and the percentage of loss relative to the total number of events
Selection
Displays information about time interval between two events. The available options are Timespan between events: a time interval between two events, with a precision of milliseconds, Interval: the number of existing events between the selected events, and Average: a time average between two selected events, with a precision of milliseconds. In case there are more than two events selected, this area only displays the Selection count option, with the number of selected events
Processing
Displays the percentage of successfully processed events in the selected file
Filters
Displays whether there is any active filter in the selected file
