Properties
Properties
This section contains information about the properties of a Query (E3Query) object.
NOTE
It is not advisable directly accessing these properties via scripts. Users must access the Query object, passing parameters through the SetVariableValue method and then modifying filters or fields through the collection returned by the GetE3QueryFields method.
The available properties on this section are the following:
CursorLocation
CursorType
DataSource
Fields
FunctionSubType
FunctionType
GroupBy
Having
IgnoreQuality
OrderBy
QueryType
SQL
Table
UaNamespaceArray
UaQueryType
Where
