FunctionType
FunctionType
Enum This property is valid when a Storage object is the Query's source (this is indicated by the DataSource property). It specifies a function that defines data generated by this Query. Some functions contain sub-functions, which can be indicated in the FunctionSubType property. The FunctionType property can assume the values described on the next table.
Available options for FunctionType
Option
Description
-1 - ftNoFunction
There is no defined function (default). This value is not available when the QueryType property is configured to 1 - qtStorage
0 - ftLastValue
Returns the last value stored on the Database
1 - ftArchivedValue
Returns a stored value relative to a certain timestamp defined in the TimeStamp variable. The type of relationship is specified in the FunctionSubType property
2 - ftTagAttribute
Returns a Tag attribute, defined in the FunctionSubType property
3 - ftCompressedDataNValues
Returns, for a single Tag, N values defined in the NumVals variable, stored from an initial time defined in the StartTime variable
4 - ftCompressedDataStartEndTime
Returns, for a single Tag, all values stored at the interval between StartTime and EndTime variables
5 - ftSampledData
Returns, for one or more Tags, the interpolated values, that is, estimated at the interval between StartTime and EndTime variables, in fixed intervals defined by the TimeInterval variable
6 - ftCalculatedData
Returns, for one or more Tags, the result of math operations applied to data at the interval between StartTime and EndTime variables, in fixed intervals defined by the TimeInterval variable
NOTE
Variables can also be defined at run time using the Query's SetVariableValue method.
