FunctionSubType
FunctionSubType
Enum Specifies a subtype of the function indicated by the FunctionType property. Only the 1 - ftArchivedValue, 2 - ftTagAttribute, and 6 - ftCalculatedData options have subtypes. For all other functions, FunctionSubType assumes the value -1 - fsNoSubType. The next table shows all possible values for this property, according to the selected function in the FunctionType property.
Subtypes for the ArchivedValue function (FunctionType equal to 1)
Subtype
Description
0 - fsPreviousArchivedValue
Value stored right before the informed timestamp
1 - fsInterpolatedArchivedValue
Calculated value, based on previous and next values
2 - fsNextArchivedValue
Value stored right after the informed timestamp
3 - fsExactArchivedValue
If a stored value is found at the exact informed timestamp
Subtypes for the TagAttribute function (FunctionType equal to 2)
Subtype
Description
0 - fsTagAttributeDescription
Tag's meaning or description
1 - fsTagAttributeSource
Tag's path being stored
2 - fsTagAttributeType
Data type: Double, Boolean, or String
3 - fsTagAttributeEU
Engineering unit
4 - fsTagAttributeLowEng
Lower limit
5 - fsTagAttributeHighEng
Upper limit
6 - fsTagAttributeDeadBand
Dead band for recording
7 - fsTagAttributeDeadBandUnit
Dead band unit (an absolute value or a percentage)
8 - fsTagAttributeMinRecTime
Minimum recording time (variations smaller than this interval are not stored)
9 - fsTagAttributeMaxRecTime
Maximum recording time (the absence of variation on these intervals forces a recording)
Subtypes for the CalculatedData function (FunctionType equal to 6)
Subtype
Description
0 - fsTotalCalculatedData
Total of values
1 - fsMinimumCalculatedData
Minimum value
2 - fsMaximumCalculatedData
Maximum value
3 - fsStandardCalculatedData
Standard deviation
4 - fsRangeCalculatedData
Range of values
5 - fsMeanCalculatedData
Mean of values
6 - fsMedianCalculatedData
Median of values
