Organizer
Organizer
The Organizer allows users to view an application as a whole, helping the edition and configuration of all involved objects by using a hierarchical tree of options. It contains the Domain and Explorer view modes.
Organizer
Organizer
The Domain mode shows only information about open objects belonging to a Domain. This information is divided into Settings, Objects Library, View, and Server Objects groups. Each group presents its objects sorted out alphabetically inside its respective node.
Domain mode
Domain mode
The Settings group shows all configured servers, as well as names of project and library files belonging to a Domain.
The Objects Library group collects ElipseX objects from all libraries in a Domain, sorted out by type (XControls, XFolders, and XObjects).
The remaining E3 objects are in View or Server Objects groups. View contains objects executing in the client machine. Objects executing in the server machine are in Server Objects.
The Explorer mode shows all projects and libraries currently open in E3 Studio, whether they belong to a Domain or not. These objects are shown inside the project or library they belong to, sorted out alphabetically.
Explorer mode
Explorer mode
Application maintenance can be handled in both modes. Operations performed in one mode are immediately reflected in the other mode. To make it easier to locate all objects, both modes are interchangeable between each other and between the Design tab in the object's View. To toggle between viewing modes, follow these procedures:
1.In Domain mode, right-click an object and select the Show in Explorer Show in Explorer option to view it in Explorer mode.
2.In Explorer mode, right-click an object and select the Show in Organizer Show in Organizer option to view it in Domain mode.
3.In either mode, right-click an object and select the Show in Editor Show in Editor option to view it on the Design tab.
4.In any object's View, on the Design tab, right-click an object and select the Show in Organizer Show in Organizer or Show in Explorer Show in Explorer option to view it in Organizer, in its respective mode.
When left-clicking an object, its properties can be viewed and edited in the Properties List, if enabled. By right-clicking an item in Organizer, the options on the next table are displayed.
Available options in Organizer
Option
Description
Close
Closes the current project, library, or library package
Refresh
Updates all settings of a project, library, or library package
Register
Registers the selected library, so that all performed changes are available
Save As
Opens a dialog box to save a project or library to the indicated location
Defragment
Defragments project, library, and library package files, that is, removes unnecessary spaces by excluding items, importing files, or including resources, among others. After defragmentation, a window is displayed with information about file's original size, file's defragmented size, and compression's percentage
Protection Protection
Protects the content of a project or library file against unauthorized edition, viewing, or execution. For more information on this option, please check chapter Security
New Folder
Creates a new Folder in an application
Insert
Inserts objects available in E3 into a project or library. For more information on this option, please check the respective chapters for each object
Insert Resource
Inserts resources into a project, library, or library packages
Enable Enable Project or Disable Disable Project project
Enables or disables the selected project. To disable it, right-click it and select the Disable project option. Notice that project's icon changes to Project disabled, indicating that it is disabled. To enable it, right-click it and select the Enable project option. NOTE: The disabled icon Project disabled is also displayed for projects that are not part of a Domain
Add to Domain Add to Domain or Remove from Domain Remove from Domain
Adds or removes a project, library, or library package from a Domain. To remove from a Domain, right-click it and select the Remove from Domain option. To add to a Domain, right-click it and select the Add to the Domain option
Find Find
Searches for parts of a text in a project. For more information on this option, please check topic Find and Replace in this chapter
Replace Replace
Searches for parts of a text in a project and replace them with others. For more information on this option, please check topic Find and Replace in this chapter
Object Counting Object Counting
Displays the number of existing objects in a Domain or in the selected object. This option is not available for the Settings, Server objects, Files, Remote Domains items, and library packages
Import Import or Export Export
Helps users to import and export objects, Links, and collections. For more information on this option, please check topic Import and Export in this chapter
Document Scripts Document Scripts
Helps users with application's scripts documentation. For more information on this option, please check topic Scripts Documentation in this chapter
Verify Verify
Verifies errors in an application. For more information on this option, please check topic Domain Verifier in this chapter
Edit Links
Changes one or more Links, user events, and Link-type properties in an application, quicker than using the traditional window. For more information on this option, please check the Links chapter
Copy or Paste Links
Copies or pastes Links from one object to another. The second option is only displayed if what was copied to the Clipboard is a Link. If the selected property already contains a Link, displays a message asking whether this Link must be overwritten. If Links copied to the Clipboard are pasted into an object that does not have one of these properties, they are listed on a message box informing this problem. The existing properties have their Links created correctly. Links from ElipseX's hidden properties are not copied
Show Class Definition Show Class Definition
Selects, on the Objects Library item, the class (XFolder, XObject, or XControl) that defines the instance of the selected ElipseX. NOTE: For password-protected classes or libraries, this option is disabled
Properties Properties
Opens an object's Properties Window. When this option is selected on a contextual menu, the first tab to open is the one to configure that object. For more information on this option, please check each object's respective chapter. NOTE: The Properties Window can also be opened by using the shortcut keys ALT + ENTER or ALT + Double-click
Load All Objects
Loads all objects from the selected group
Close All Objects
Closes all objects from the selected group
Save All Objects Save All Objects
Saves all objects from the selected group
New Application File (.PRJ)
Creates a new project file and adds it to a Domain
New Objects Library (.LIB)
Creates a new library file and adds it to a Domain
Register Loaded Libraries Register Loaded Libraries
Registers all libraries loaded in a project (CTRL + SHIFT + L)
Open All Files
Traverses all project and library files in a Domain. If a closed file is found, it is then opened. If a file is protected by an edition password, this password is then requested. E3 Studio tries to use the same password for all protected files. If this password fails for any of these files, it is then requested again
Close All Files
Closes all project and library files in a Domain. If any file has unsaved changes, E3 Studio then displays a message asking users whether they want to save them or not
Edit Domain activation order
Allows changing the activation order of Server objects in a Domain, as shown on the next figure
Extract Libraries Extract Libraries
Allows extracting libraries inside a library package, that is, a file with an .e3pkg extension
NOTE
The options on the previous table are also available by using the shortcut key SHIFT + F10, which corresponds to the application or menu key Application or menu key.
Domain's Activation Order window
