ActiveX
ActiveX
ActiveX objects are COM-based (Component Object Model) software components that can be inserted into an application to perform several tasks. These objects are developed in programming languages such as C/C++, Delphi, and Visual Basic, among others.
Some ActiveX objects are automatically registered when E3 is installed: E3Alarm, E3Browser, and E3Chart (developed by Elipse Software); Microsoft Forms (developed by Microsoft); and Report (ActiveReports, developed by Data Dynamics). E3Alarm, E3Browser, E3Chart, and Report objects have specific chapters further in this Manual. Microsoft Forms objects are described in another topic on this chapter.
NOTE
For ActiveX objects not previously installed by E3, these objects must be installed in all computers where an application is executed, specially on Remote E3 Viewers.
In addition to these ones, users can insert any ActiveX object. To register an ActiveX in E3, follow these procedures:
1.Open the Tools - Manage Active X menu. The following dialog box is then displayed.
ActiveX Control configuration window
Available options for ActiveX Control configuration window
Option
Description
Registered controls in Windows
List with all ActiveX controls registered in Windows and that can be added to E3
Registered controls in E3
List with all ActiveX controls already registered in E3
Register
Registers the selected control in E3. If this control is not compatible with E3, a dialog box is then displayed warning users about this incompatibility
Remove
Removes the selected control from the Registered controls in E3 list, moving it back to the Registered controls in Windows list. Controls with an ActiveX cannot be removed icon cannot be removed, only the ones with an ActiveX can be removed icon
Browse
Opens a dialog box to search for an ActiveX file
Refresh
Allows updating ActiveX controls on the Registered controls in Windows list, which were registered after opening this configuration window
Close
Closes the ActiveX Control configuration window
2.Click Browse to open a dialog box and locate a file that contains an ActiveX.
Locating an ActiveX file
3.Select the file and then click Open.
There are two types of ActiveX objects: Graphical (used in application Screens) and Non-Graphical (perform any data manipulation).
Graphical objects can be inserted on an application in three different ways:
By selecting the appropriate object on the toolbar of a Screen
By right-clicking a Screen object in Organizer and then selecting the Insert option
By right-clicking a Screen and selecting the Insert option
Inserting a graphical object on a Screen
Non-graphical objects can be used on applications via scripts, and they are created with VBScript's CreateObject standard method.
